查看: 12261|回复: 0
For a reduced outlet branch connection (B31.3), stress at the branch is calcu
发表于 2009-2-4 09:14:00 | 显示全部楼层 |阅读模式
在2009-02-04,seminar@sstusa.com 写道:
-=SST Systems=-
CAEPIPE
Pipe Stress Analysis
Software
* Doubles your Productivity
at Half the Cost! *
SST Systems, Inc.
1798 Technology Dr., Ste 236
San Jose, CA 95110
Tel: +1 408 452 8111
Fax: +1 408 452 8388
Web: http://www.sstusa.com/
Hello,
Here is a technical tip from Mr. Ron Haupt, the former ASME B31 chairman teaching a (More Information) seminar this month on Pipe Design and Stress Analysis.
_________________________________________________________
Question : For a reduced outlet branch connection (B31.3), stress
at the branch is calculated using the “corroded section modulus.”
True or False? Answer below.
Can you answer the above question? Don\'t look at the answer. You will learn a lot more than an answer to this simple question at the seminar (last 6 spots left, fee discounted 20% + comes with a free DVD on "Piping Codes").
More Info (More Information)
Answer: Not True. Stress at the branch should be
calculated using an “effective section modulus” not
See ASME B31.3 Para. 319.4.4 for details.
For any other inquiries please email -- krolik@sstusa.com
Telephone: 408-452-8111, option 0 (zero).
Thank you.
Best Regards,
Mik Krolik
Piping Seminar Coordinator
If you no longer wish to receive these emails please send a blank message to seminar@sstusa.com with the words "opt out" in the subject line
